Clear the Peer Connection
Clear the peer connection to clear the TCP connection to the specified MSDP peer and reset all
MSDP message counters.
This procedure does not clear the SA cache entries the router learns from the peer.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#clear ip msdp peer 21.0.0.2
Variable definitions
The following table defines parameters for the clear ip msdp peer command.
Variable |
Value |
{A.B.C.D} |
Specifies the MSDP peer IP address. |
vrf WORD<0–16> |
Specifies the VRF name. |
vrfids WORD<0–512> |
Specifies the VRF ID. |
